Product
Brand
C2G 10m IEEE-1284 DB25 M/M Parallel Cable
Quicklinx: 684SWS00 Mfr#: 81476
High-speed IEEE-1284 compliant cable from C2G ensures you realize the added speed and two way communications offered by your newer printers, HP tape drives, Iomega devices, scanners and more. This advanced technology, which defines high-speed, bi-directional communications between PC and peripheral, requires both high quality connectors and a specialized wire-type to handle the increased data rates.
C2G parallel cable - 10 m
Parallel cable
Double shielded twisted pair
Molded
Length
10 m
Connector
DB-25 - male
Connector (Second End)
DB-25 - male
RoHS
Parallel cable
Shielding Material
Foil with braid
Molded
Length
10 m
Connector
25 pin D-Sub (DB-25) - male
IEEE-1284, RoHS
