C2G 10m DisplayPort Cable with Latches M/M – Black
Quicklinx: 9MSBWS00 Mfr#: 84405
£25.72 ex VAT
£30.86 inc VAT
This cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DisplayPort input. This cable carries a digital audio/video signal and the connectors feature latches which secure the cable in the port. Support of a Reduced Bit Rate (RBR) bandwidth means that this cable can carry up to a 1920x1080 resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
  • Resolution Support
    1920 X 1080
  • DisplayPort Specification
    DisplayPort 1.2 Standards
  • Cable Colour
C2G 10m DisplayPort Cable with Latches 8K UHD M/M - 4K - Black - DisplayPort cable - 10 m
DisplayPort cable
Latched
Length
10 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
DisplayPort cable
Latched
Length
10 m
Connector
20 pin DisplayPort - male
DisplayPort 1.2
