C2G 10M Active HDMI High Speed Cable CL3
Quicklinx: D0BXWS00 Mfr#: 80546
Length: 10m
Select:
Hurry, only 3 left in stock!
£57.89 ex VAT
£69.46 inc VAT
The Active High-Speed HDMI cable is the perfect solution for extending HDMI signals in classrooms, conference rooms, boardrooms, and other commercial environments requiring a reliable long-distance connection up to 30 feet (10 metres). The Active HDMI cable features a built-in signal booster that supports HDMI A/V connections at longer distances than non-active cables, allowing you to connect your Blu-Ray player, Laptop, Chromebook or other HDMI device to your HDTV, projector or HDMI-capable display up to 10 metres apart with no signal loss. This cable does not require an external power adapter and supports 1080p resolution at 60 Hz, 3D video, Deep Colour and detailed image display. Additionally, EDID and HDCP are supported for compatibility with HDMI source devices, displays, and content. Combine this active HDMI cable with wall plates for a clean, professional connectivity solution that can be used with projectors in classrooms, conference rooms, or training rooms.
  • Colour
  • Warranty
    3 Years
  • Connector 1
    (1) HDMI Male
  • Connector 2
    (1) HDMI Male
C2G 10m Active High Speed HDMI Cable In-Wall, CL3-Rated - HDMI cable - 10 m
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
28
Length
10 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
CL3 rated jacket, HDMI CEC support (Consumer Electronics Control), in wall mounting, HDCP compliant, active converter
3-year warranty
Cable Type
HDMI cable
Double shielded
28
Jacket Material
PVC
Shielding Material
Aluminium foil with aluminium-magnesium braid
Length
10 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
EDID compatible
Limited warranty - 3 years
Length: 10m
Brand: C2G
