Use RJ45 10-pin/DB25M Modular Adapters bY-C2G for applications where all your serial lines need to be present. It is great for extending an external modem to a DB9 or DB25 PC port. You may be used to connect Digiboard or Boca board products requiring ring indicator and carrier detection-pins.
- C2G Modular Adapter - serial adapter - RJ-45 (10 pin) to DB-25
- Serial adapter
- Connector
- RJ-45 (10 pin) - female
- Connector (Second End)
- 25 pin D-Sub (DB-25) - male
- Grey
- Serial adapter
- Grey
- Connector
- RoHS
