With C2G's USB to IEEE-1284 Printer Cable, you can use your USB port on your PC or hub and free-up the parallel port for a Zip drive or scanner. If you have multiple printers, you can eliminate the need for a switchbox by connecting each printer to a USB port. The device is fully transparent to the user, and is ideal for true bi-directional communication.
- C2G USB to IEEE-1284 Printer Cable - parallel adapter
- Parallel adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- IEEE 1284
- Data Link Protocol
- Parallel
- Beige
- System Requirements
- Microsoft Windows 98/ME/2000/XP, Microsoft Windows Vista
- 1 year warranty
- Parallel adapter
- Form Factor
- External
- USB
- Ports
- IEEE 1284
- Connectivity Technology
- Wired
- Parallel
- 1 x IEEE 1284 (EPP/ECP) - 36 PIN Centronics
- Connections
- 1 x USB - 4 pin USB Type A
- Cables Included
- 1 x USB cable (integrated) - 1.8 m
- Beige
- OS Required
- Limited warranty - 1 year
