Experience 4K ULTRA HD displays with this USB-C to HDMI Adapter Cable which provides a fast and reliable connection between a USB Type C enabled Chromebook, laptop, tablet or other device and an HDTV, projector or other HDMI-equipped display – making it an ideal solution for the office, work space applications or home use. Supporting resolutions up to 4K @ 60Hz, which is four times the clarity of 1080p, this cable offers high quality, ULTRA HD video image. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The cable form factor of this adapter provides a simple and convenient one-cable solution that eliminates the need for a separate adapter or additional cabling.
- C2G 1.8m (6ft) USB C to HDMI Adapter Cable 4K - Audio / Video Adapter - Black - external video adapter - black
- External video adapter
- Bus Type
- USB-C
- Max Resolution
- 3840 x 2160
- HDMI (male connector)
- Length
- 1.8 m
- Enclosure Colour
- Black
- 3-year warranty
- Bus Type
- USB-C
- Max Resolution
- 3840 x 2160 at 60 Hz
- Plug and Play, RoHS 2 (2011/65/EU)
- Length
- 1.8 m
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 45 °C
