For fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6A TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels with a LSZH outer jacket. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily colour-code your network installation. Each cable is individually labelled with the length for ease of use.
Connector 1: (1) RJ-45 Male.
Connector 2: (1) RJ-45 Male.
- C2G patch cable - 1.5 m - red
- Patch cable - CAT 6a
- Technology
- Wires per Cable
- 8 wires
- Booted, snagless, minimised Near-End Crosstalk (NEXT), reduced structural return loss (SRL), latching clip
- Length
- 1.5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Red
- Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 1.5 m
- 68 g
- Red
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, TIA/EIA-568-B.2
