C2G 0.5m Velocity[TM] DB9 Female to 3.5mm Male Adapter Cable
Quicklinx: DWQQWS00 Mfr#: 87188
Length: 50cm
£6.74 ex VAT
£8.08 inc VAT
Why run cables for RS-232 control of your audio/video system, when you can use this easy adapter? The Velocity RS-232 adapter leverages your DB9 or 3.5 mm stereo audio cable to run 3-conductor RS-232 control signals between your control unit and your video display. Fully molded DB9 and 3.5 mm connectors provide excellent strain relief. This adapter is ideal for use with computers, projectors, and any control unit/display requiring 3-conductor RS-232 serial control.
C2G Velocity DB9 Female to 3.5mm Male Adapter Cable - serial cable - stereo mini jack to DB-9 - 50 cm
Serial cable
Molded, thumbscrews, strain relief
Length
50 cm
Connector
Mini-phone stereo 3.5 mm - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Serial cable
Length
50 cm
Connector
Length: 50cm
Brand: C2G
Price Range Ex VAT: 0 - 50
