C2G 0.5m Ultraflex Gripping Connector HDMI Cable
Quicklinx: DWKXWS00 Mfr#: 82377
Length: 50cm
Select:
£9.09 ex VAT
£10.90 inc VAT
Experience ULTRA HD (4K) displays with this High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). This high retention cable is equipped with gripping connectors which provide 3 times greater port retention than standard HDMI connectors, ensuring that your devices maintain signal over longer periods of time without interruption. This High-Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming console, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. The cable is also backwards compatible with PlayStation 3 (PS3) and Xbox 360. The Ethernet capabilities of the cable allow users to connect multiple Ethernet-enabled HDMI devices through a single Ethernet connection. This fully-functional, high bandwidth cable is tested to perform at industry standards and is back by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
  • Colour
  • Warranty
    Lifetime
  • Connector 1
    (1) HDMI Male
  • Connector 2
    (1) HDMI Male
C2G 0.5m High Speed HDMI Cable with Gripping Connectors - HDMI with Ethernet cable - 50 cm
Cable
Shielded
American Wire Gauge (AWG)
30
Length
50 cm
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K support
Cable Type
HDMI with Ethernet cable - 4K support
Shielded
30
Shielding Material
Length
50 cm
Plated Connector
Gold
Gripping connectors
Connector
19 pin HDMI Type A - male
CEC
102 g
Limited warranty - lifetime
Length: 50cm
Brand: C2G
Price Range Ex VAT: 0 - 50
