C2G 0.5m UK Laptop Power Cord (BS 1363 to IEC 60320 C5)
Quicklinx: 98PDWS00 Mfr#: 80600
Length: 50cm
£3.88 ex VAT
£4.65 inc VAT
Replace your overused or misplaced power cable, or just get some extra cords for convenience. This power cord is designed to work with laptops that use a 3-slot power cord. This 18 AWG cord features a fully moulded design for maximum durability and long life. The female connector, often called a Clover Leaf connector, plugs directly into the device while the male connector plugs into a standard outlet.
  • Product Use
    UK replacement power cord for many laptops
  • Warranty Details
    This product carries a lifetime warranty
  • Connector Information
    The female connector is often called a Clover Leaf connector
C2G Laptop Power Cord - power cable - 50 cm
Power cable
Molded
Length
50 cm
United Kingdom
Connector
Power IEC 60320 C5
Connector (Second End)
Power BS 1363 - male
Rated Voltage
AC 250 V
Power cable
American Wire Gauge (AWG)
18
Rated Voltage
AC 250 V
Molded
Length
50 cm
United Kingdom
Connector
Power IEC 60320 C5
Length: 50cm
Brand: C2G
Price Range Ex VAT: 0 - 50
