C2G 0.5m Thunderbolt 3 Cable (40Gbps) - 4K support - Black
Quicklinx: D6VNWS00 Mfr#: 88837
Length: 50cm
Hurry, only 3 left in stock!
£26.47 ex VAT
£31.76 inc VAT
Thunderbolt 3 brings lightning-speed data transfer, dual 4K at 60Hz video support, high bit depth audio, and power delivery up to 100W. Deliver up to 40Gbps to or from a Thunderbolt 3 enabled port. Whether uploading or downloading data, this cable is an ideal solution to transfer large amounts of information such as high-resolution photos for editing or storage, 3D models for video game authoring or HD video for editing. Whether you’re desk-based or on-the-road, this lightweight, portable one-cable solution ensures that your Thunderbolt 3 equipped laptop, smartphone, or tablet is fully charged and ready to go whilst displaying ULTRA HD video content, transferring files, or streaming audio. Deliver up to 100W of charging power to or from the connected device with smart power delivery. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
  • Colour
  • Warranty
    3 years
  • Connector 1
    USB-C Male
  • Connector 2
    USB-C Male
C2G 0.5m Thunderbolt 3 Cable (40Gbps) - Thunderbolt Cable 4K - Black - Thunderbolt cable - 50 cm
Thunderbolt cable
4K support, sync and charge
Length
50 cm
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
30 V
Thunderbolt 3
3-year warranty
Thunderbolt cable
American Wire Gauge (AWG)
32
Rated Voltage
30 V
Length
50 cm
29.4 g
Connector
24 pin USB-C - male
24 pin USB-C - male
Thunderbolt 3
3-year warranty
Length: 50cm
Brand: C2G
Price Range Ex VAT: 0 - 50
