C2G 0.5m Cat6 UTP LSZH Network Patch Cable - Blue
Quicklinx: CMHGWS00 Mfr#: 82459
For fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels with a LSZH outer jacket. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily colour-code your network installation. Each cable is individually labelled with the length for ease of use.
Connector 1: (1) RJ-45 Male.
Connector 2: (1) RJ-45 Male.
  • Colour
    Blue
  • Warranty
    Lifetime
  • Length
    0.5 Low metres
  • Connector A
    RJ-45 Male
  • Connector B
    RJ-45 Male
C2G patch cable - 50 cm - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Booted, snagless, minimised Near-End Crosstalk (NEXT), reduced structural return loss (SRL), latching clip
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Patch cable - CAT 6
Jacket Material
Low Smoke Zero Halogen (LSZH)
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
50 cm
32 g
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, TIA/EIA-568-B.2
