Make your work environment more flexible and efficient. This heavy-duty 18 AWG cord is designed to work with monitors, scanners, printers, and other devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into another power cord.
- C2G Computer Power Cord Extension - power extension cable - 0.5 m
- Power extension cable
- Length
- 0.5 m
- Connector
- Power IEC 60320 C13
- Connector (Second End)
- Power IEC 60320 C14
- Rated Voltage
- AC 250 V
- Limited lifetime warranty
- American Wire Gauge (AWG)
- 18
- Rated Voltage
- AC 250 V
- Length
- 0.5 m
- Connector
- RoHS
