C2G 0.5m 16 AWG Universal Power Cord (IEC320C13 to BS 1363)
GREAT VALUE POWER CABLING FROM CABLES TO GO!
Quicklinx: 63TQWS00 Mfr#: 88511
Type: Power
£3.77 ex VAT
£4.52 inc VAT
Replace your overused or misplaced power cable, or just get some extra cords for convenience. This universal power cord is designed to work with most desktop PCs, monitors, scanners, printers and other devices that use the 3-pin shroud power connector. Plus this heavy-duty 16 AWG cord features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into a standard outlet.
C2G Universal Power Cord - power cable - BS 1363 to IEC 60320 C13 - 50 cm
Power cable
Molded
Length
50 cm
Connector
Power BS 1363 - male
Connector (Second End)
Power IEC 60320 C13
Power cable
American Wire Gauge (AWG)
16
Molded
Length
50 cm
Connector
Power IEC 60320 C13
Type: Power
Brand: C2G
Price Range Ex VAT: 0 - 50
