Product
Brand
C2G .5m DB9 F/F Null Modem Cable - Beige
Quicklinx: 682XWS00 Mfr#: 81411
Null modem serial cables from C2G allow two DTE or DCE devices to communicate with no conflict in data transmission. These transmit and receive signals are crossed to ensure proper data transmission. These high quality-Cables deliver data quickly and reliably over short distances. Cables in male-to-female configurations are typically used as serial printer cables, while female-to-female versions are typically connecting two PC serial ports. Don't forget, custom lengths are the area of specialization.
C2G null modem cable - 50 cm
Null modem cable
Shielded
Thumbscrews
Length
50 cm
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
Null modem cable
Shielded
Thumbscrews
Length
50 cm
Connector
RoHS
