Null modem serial cables from C2G allow two DTE or DCE devices to communicate with no conflict in data transmission. The transmit and receive signals are crossed to ensure proper data transmission. These high quality-cables deliver data quickly and reliably over short distances. Cables in male-to-female configurations are typically used as serial printer cables, while female-to-female versions are typically connecting two PC serial ports.
- C2G - null modem cable - DB-25 to DB-9 - 50 cm
- Null modem cable
- Technology
- Shielded
- Length
- 50 cm
- Connector
- 25 pin D-Sub (DB-25) - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - female
- Null modem cable
- Technology
- Shielded
- Length
- 50 cm
- Connector
- RoHS
