This Cat6 network crossover patch cable is an ideal solution for connecting two computers to share files or data. The crossed pin configuration allows two computers to be connected peer-to-peer without the need for a hub or switch. This cable may also be used to connect network switches and hubs without an uplink port to other switches and hubs. This cable has been designed to reduce both impedance and structural return loss (SRL) which ensures error-free transmission. Constructed from high quality cable and a shortened body plug, this design minimizes Near-End Crosstalk levels. This patch cable provides the necessary throughput and is able to handle high speeds. The booted, snagless design prevents unwanted cable snags during installation without impairing the ability to insert and remove the connector from the port. It also provides unparalleled strain relief so that the cable is not damaged even when pulled excessively.
- C2G Cat6 Booted Unshielded (UTP) Crossover Patch Cable - crossover cable - 50 cm - grey
- Crossover cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 50 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Grey
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 50 cm
- Grey
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
