C2G .5m Cat6 550 MHz Snagless Crossover Cable - Grey
Quicklinx: 6BRWWS00 Mfr#: 83505
This Cat6 network crossover patch cable is an ideal solution for connecting two computers to share files or data. The crossed pin configuration allows two computers to be connected peer-to-peer without the need for a hub or switch. This cable may also be used to connect network switches and hubs without an uplink port to other switches and hubs. This cable has been designed to reduce both impedance and structural return loss (SRL) which ensures error-free transmission. Constructed from high quality cable and a shortened body plug, this design minimizes Near-End Crosstalk levels. This patch cable provides the necessary throughput and is able to handle high speeds. The booted, snagless design prevents unwanted cable snags during installation without impairing the ability to insert and remove the connector from the port. It also provides unparalleled strain relief so that the cable is not damaged even when pulled excessively.
C2G Cat6 Booted Unshielded (UTP) Crossover Patch Cable - crossover cable - 50 cm - grey
Crossover cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
50 cm
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
