C2G .5m 75 Ohm BNC Cable
Quicklinx: 67W1WS00 Mfr#: 80364
Type: Video
Length: 50cm
£4.82 ex VAT
£5.78 inc VAT
high quality 75-ohm BNC cables from C2G are ideal for video applications including CCTV, broadcast, studio, boardroom presentation, home cinema, etc. Manufactured from coax cable and nickel plated BNC connectors. A molded PVC strain relief protects the cable from wear over time.
C2G video cable - 50 cm
Cable
Video cable
Double shielded coaxial
American Wire Gauge (AWG)
22
Length
50 cm
Connector
BNC - male
Connector (Second End)
BNC - male
RG-59
Moulded
Cable Type
Video cable
22
Jacket Material
PVC
Shielding Material
Foil with copper braid
Impedance
75 Ohm
RG-59
Length
50 cm
Plated Connector
Nickel
Moulded
Connector
BNC - male
BNC - male
RoHS
Type: Video
Length: 50cm
Brand: C2G
Price Range Ex VAT: 0 - 50
