C2G .5m 7-pin Serial ATA Device Cable
Quicklinx: 687CWS00 Mfr#: 81818
Length: 50cm
Type: SATA
Hurry, only 1 left in stock!
£4.72 ex VAT
£5.66 inc VAT
Serial ATA cables by C2G are designed to handle the differential signals implemented in today's technology. This ensures increased throughput and reduced data packet loss. The 7-pin Serial ATA cables permit higher data transmission rates, reduce crosstalk and improve signal integrity. Reduce overheating and save internal space within the CPU unit for easy movement when adding or removing hard drives, PCI cards or other adapters.
C2G SATA cable - 50 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Length
50 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
Red
Storage Cable Type
SATA cable
Interface Speed
Length
50 cm
Red
Connector
Length: 50cm
Type: SATA
Brand: C2G
Price Range Ex VAT: 0 - 50
