Buffalo’s WBMR-300HPD series modem routers unlock extensive capabilities and potential not normally found in similar routers. With DD-WRT NXT pre-installed, and root-level device management, Buffalo’s AirStation N300 wireless modem router is highly configurable with a breadth of powerful features. The WBMR-300HPD series modem router also comes with Buffalo’s HighPower technology reducing dead spots, extending your wireless range, and ensuring good performance in difficult-to-reach places. Furthermore, multiple levels of wireless and wired security are available, keeping your computer and network secure.
Multiple levels of security management
The Buffalo AirStation N-Technology high power ADSL2+ modem router supports multiple levels of wireless and wired security: WPA2, WPA-PSK (TKIP, AES) and 128/64-bit WEP Security. -
Dead spots eliminated
The Buffalo AirStation N-Technology high power ADSL2+ modem router is powered by Buffalo’s unique high power technology. High power technology reduces dead spots and extends the range in and around the home or small office to ensure good wireless performance even in those difficult-to-reach places.
- BUFFALO AirStation WBMR-300HPD - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 3-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- Firewall protection, NAT support, VPN support, VLAN support, Stateful Packet Inspection (SPI), packet filtering, VPN passthrough, Access Point operational mode, MIMO technology, Quality of Service (QoS), DHCP server, Buffalo High Power technology, wireless bridge mode, Direct Sequence Spread Spectrum (DSSS), DNS caching, wireless extender mode
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
- Power
- AC 120/230 V (50/60 Hz)
- 16.5 cm x 3.5 cm x 15.8 cm
- 350 g
- System Requirements
- Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Apple MacOS X 10.5 - 10.11
- 3-year warranty
- Wireless router - 3-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
- Authentication Method
- RADIUS
Line Properties
- Line Coding Format
- OFDM
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.3 (G.DMT.bis), ITU G.992.5 Annex A
- LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Gain Level
- 5 dBi
- Power Device
- External power adapter
- Voltage Required
- 7 Watt
- Included Accessories
- Vertical stand
- Cables Included
- 1 x network cable
- Software Included
- DD-WRT for Buffalo
- OS Required
- 16.5 cm
- 3.5 cm
- 15.8 cm
- 350 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
