Buffalo Wireless N300 ADSL2+ Modem Router
Quicklinx: D0LSWS00 Mfr#: WBMR-300HPD-EU
  • IEEE 802.11n
Buffalo’s WBMR-300HPD series modem routers unlock extensive capabilities and potential not normally found in similar routers. With DD-WRT NXT pre-installed, and root-level device management, Buffalo’s AirStation N300 wireless modem router is highly configurable with a breadth of powerful features. The WBMR-300HPD series modem router also comes with Buffalo’s HighPower technology reducing dead spots, extending your wireless range, and ensuring good performance in difficult-to-reach places. Furthermore, multiple levels of wireless and wired security are available, keeping your computer and network secure.
  • Multiple levels of security management
    The Buffalo AirStation N-Technology high power ADSL2+ modem router supports multiple levels of wireless and wired security: WPA2, WPA-PSK (TKIP, AES) and 128/64-bit WEP Security.
  • Dead spots eliminated
    The Buffalo AirStation N-Technology high power ADSL2+ modem router is powered by Buffalo’s unique high power technology. High power technology reduces dead spots and extends the range in and around the home or small office to ensure good wireless performance even in those difficult-to-reach places.
BUFFALO AirStation WBMR-300HPD - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 3-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
2
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Firewall protection, NAT support, VPN support, VLAN support, Stateful Packet Inspection (SPI), packet filtering, VPN passthrough, Access Point operational mode, MIMO technology, Quality of Service (QoS), DHCP server, Buffalo High Power technology, wireless bridge mode, Direct Sequence Spread Spectrum (DSSS), DNS caching, wireless extender mode
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
16.5 cm x 3.5 cm x 15.8 cm
350 g
Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Apple MacOS X 10.5 - 10.11
3-year warranty
Wireless router - 3-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
Authentication Method
RADIUS
Line Properties
Line Coding Format
OFDM
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.3 (G.DMT.bis), ITU G.992.5 Annex A
LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
2
Gain Level
5 dBi
External power adapter
7 Watt
Vertical stand
1 x network cable
Software Included
DD-WRT for Buffalo
16.5 cm
3.5 cm
15.8 cm
350 g
Limited warranty - 3 years
10 - 85% (non-condensing)
