The new Buffalo AirStation Wireless Router (WHR-1166D-EU) is ready for the latest 11ac smartphones, tablets, or laptops and designed especially for users focused on their wireless connections.
The WHR-1166D provides up to 866 Mbps transfer speed in the 5GHz band and simultaneous transfer speeds of up to 300 Mbps in the 2.4GHz band. Furthermore, easy setup is a few clicks away via a simple User Interface that's accessible on a computer, smartphone, or tablet. Buffalo's new AirStation is also very family-friendly with Norton ConnectSafe web filtering as well as Parental Control that allows you to limit the amount of time specific users are connected.
And for more advanced users the WHR-1166D also has functionalities like QoS, port forwarding and guest port. The guest port feature allows you to both share your internet connection with visitors and also isolate your own network devices - keeping you, and your guests, entirely separate. Buffalo's new AirStation can also be integrated into an existing network as a wireless range extender for even better and further reach.
Dual band 11ac with great wireless performance and security, Buffalo's new AirStation WHR-1166D-EU is a smart choice for homes and small office networks looking to upgrade their network with a fast 11ac wireless router.
LAN Ports - 4x100mbps RJ45 Auto MDIX
WAN Ports - 1x Gigabit RJ45 Auto MDIX
Dual band
Offering simultaneous wireless operation on both the 2.4 GHz and 5 GHz bands, Buffalo AirStation WHR-1166D is perfect for streaming HD movies, music and emailing from multiple devices at the same time. -
Backward compatibility
Along with greatly enhanced speeds, 11ac features improved reliability and range and it is backward compatible with 802.11n to support your most recent wireless devices. -
Wireless security
The WHR-1166D offers the best security standards available, featuring multi-level wireless encryption options to prevent unauthorized access and protect your important data. -
Easy, secure setup
The Buffalo AirStation One-Touch Secure System (AOSS) and Wi-Fi Protected Setup (WPS) provide a quick and easy way to create a secure wireless connection to a host within minutes. -
New-and-improved user interface
A user interface has been designed to provide users one-click access to their most commonly accessed settings. Simple toggles and buttons provide a familiar and easy navigation experience.
- BUFFALO AirStation WHR-1166D - wireless router - 802.11 a/b/g/n/ac - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Data Transfer Rate
- 1166 Mbps
- PPTP
- NAT support, auto-uplink (auto MDI/MDI-X), packet filtering, Intrusion Detection System (IDS), MAC address filtering, parental control, Airstation OneTouch Secure System (AOSS), MIMO technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), hidden SSID, Buffalo High Power technology, port forwarding, Stateful Packet Inspection Firewall (SPIF), Direct Sequence Spread Spectrum (DSSS), VPN Server
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- Power
- AC 120/230 V ( 50/60 Hz )
- 5.5 cm x 13 cm x 15.9 cm
- 280 g
- System Requirements
- Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.5 - 10.9
- 3 years warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz, 5 GHz
- 1166 Mbps
- PPTP
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
- Authentication Method
- Radio Service Set ID (SSID)
Line Properties
- Line Coding Format
- CCK, OFDM
- LAN : 4 x 10Base-T/100Base-TX - RJ-45 ¦ WAN : 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- External power adapter
- Voltage Required
- 10.8 Watt
- Included Accessories
- Vertical stand
- Software Included
- Norton ConnectSafe
- OS Required
- 5.5 cm
- 13 cm
- 15.9 cm
- 280 g
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
