Your basket is empty
Buffalo WHR-600D Dual band AirStation Wireless Router
Quicklinx: 962KWS00 Mfr#: WHR-600D-EU
  • IEEE 802.11n
  • Windows 8 (32/64 bits)
Stand Out in The Crowd: Buffalo's New AirStation™ and the Advantage of 5.0GHz
The new Buffalo AirStation™ HighPower Wireless Router (WHR-600D-EU) provides up to 300Mbps transfer speeds simultaneously in the 2.4GHz and 5GHz bandwidths: taking advantage of the less-crowded 5.0GHz spectrum which is especially beneficial for new mobile phones, tablets, and laptops.
But perhaps best of all, Buffalo's new router also facilitates multiple simultaneous levels of security to keep your computer and network secure when using devices with lower levels of encryption such as gaming consoles or other devices.
Dual band
Dual band with simultaneous transfer speeds up to 300 Mbps in both the 2.4GHz and 5.0GHz spectrums
Backwards compatibility
Creates draft 802.11n (Dual Band - 2.4 GHz/5 GHz), 802.11g/b and 802.11a wireless networks and is backwards compatible with 802.11b/g and 802.11a devices.
Easy setup
Easy setup with WPS or AOSS™
Wireless Security
WPA2-PSK (AES, TKIP), WPA-PSK (AES, TKIP), WPA/WPA2 mixed PSK, 128/64-bit WEP, Mac Address Filter, Hidden SSID, Privacy Separator
WAN Security
Dynamic Packet Filtering, Intrusion Detector, NAT/SPI Firewall with VPN Multi-Pass Through
VPN
Access the network remotely
3 Year Warranty
BUFFALO AirStation WHR-600D - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
Firewall protection, NAT support, auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), packet filtering, Intrusion Detection System (IDS), MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, Airstation OneTouch Secure System (AOSS), MIMO technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), port forwarding, Direct Sequence Spread Spectrum (DSSS)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
5.5 cm x 15.9 cm x 13 cm
275 g
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.5 - 10.8
3 years warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
Authentication Method
Radio Service Set ID (SSID)
Line Properties
Line Coding Format
OFDM
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
External power adapter
8.2 Watt
5.5 cm
15.9 cm
13 cm
275 g
Limited warranty - 3 years
10 - 85% (non-condensing)
962K C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.07
962K C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.55
962K C2G 2m Cat6a Shielded Patch - Blue In Stock £6.44
962K C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £40.80
