Providing seamless integration with a range of computers and servers, TeraStation 5600 WSS incorporates the powerful processor and high-performance RAM, allowing you to experience maximum network throughput while NAS and iSCSI targeting operations run simultaneously. Additionally, support for NTFS for very specific file-level security and Native Active Directory support provides integration with large networks. TeraStation 5600 WSS is a perfect solution for highly reliable and continuously available high-performance network storage for a variety of data needs. TeraStation 5600 WSS offers a host of business-class features along with unlimited users and seamless integration into different environments.
Unified storage
TeraStation 5600 WSS has simultaneous NAS and iSCSI operation in one unit for simple and effective storage and device management. Boost resource flexibility and efficiency and increase space utilization. -
High performance
TeraStation 5600 WSS features the powerful processor, providing exceptional performance during file transfers and everyday NAS functions. Experience maximum network throughput while NAS and iSCSI targeting operations run simultaneously. -
Reliable and secure network storage
TeraStation 5600 WSS offers high-capacity, highly available storage accessible among multiple platforms for seamless centralized storage and backup. Create user and group profiles and control folder and file access to protect business-critical content and privacy. Support for multiple levels of RAID provides continuous data protection and increased fault tolerance and data availability. -
Storage virtualization
Configure TeraStation 5600 WSS as an iSCSI target to add virtualized storage to your business network. Storage virtualization serves to decrease IT spending by maximizing the resources offered by servers while providing optimal server scalability and reliability. A virtualized environment removes a significant amount of server dependence, shifting the burden to the storage devices. -
Data protection and backup
TeraStation 5600 WSS features Buffalo's replication technology providing easy and high-performance data replication from one Buffalo NAS device to another Buffalo NAS device over the network or the Internet. This offers real-time synchronous replication of data, providing easy, continuous data protection in the event of data loss. -
Remote file access
TeraStation 5600 WSS offers remote access to share your important data for enhanced collaboration and productivity. With FTP / FTPS servers, you can securely access and share files with anyone outside the local network.
- BUFFALO TeraStation 5600 WSS - NAS server - 24 TB
- NAS server
- Bundled Services
- 3 years 24-hour TeraStation VIP HDD Exchange Service
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 24 TB
- Max Supported Capacity
- 24 TB
- Installed Devices / Modules Qty
- 6 (installed) / 6 (max)
- 17 cm x 23 cm x 30 cm
- 10 kg ()
- Processor
- 1 x Intel Atom D2700 2.13 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, 5, JBOD
- Hard Drive
- 6 x 4 TB SATA 3Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Microsoft Windows Storage Server 2012 R2 Standard
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.4 - 10.9, Windows 8 / 8.1, Microsoft Windows RT / RT 8.1, Windows 10
- 3-year warranty
- NAS server
- Bundled Services
- Host Connectivity
- Gigabit Ethernet
- 24 TB
- 24 TB
- 17 cm
- 23 cm
- 30 cm
- 10 kg ()
- Built-in Devices
- Status LCD
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 4 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 6 x 4 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), Server Message Block (SMB)
- LDAP support, wake on LAN (WOL), print server, DFS support, Remote Desktop Protocol (RDP) support, Jumbo Frames support, DLNA Media Server, NTP time synchronisation
- DLNA CERTIFIED
- Expansion Bays
- 6 (total) / 0 (free) x hot-swap
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x serial - DB-9
- Device-to-device data replication
- Power Device
- Internal power supply
- Voltage Required
- 120 Watt
- Software Included
- NovaBACKUP Business Essentials (10 licences)
- OS Required
- Limited warranty - 3 years
