Buffalo's TeraStation 5600DWR series delivers advanced 6-bay NAS and comes fully populated with high-reliability drives: perfect for production environments, medium, large, and growing businesses and demanding users. The TS5600DWR performs exceptionally during file transfers and everyday NAS functions thanks to its powerful processor, fast memory, and multiple USB ports - including USB 2.0 and USB 3.0. The TS5600DWR also includes business-critical applications such as IP camera recording, remote access, support for iSCSI target, and numerous levels of RAID for customizable capacity and redundancy depending on your specific needs. The TS5600DWR is packed with backup features such as failover, replication, scheduled backups, and a special Buffalo Media Cartridge feature that works like a tape media backup. Managing data, backups, and data sharing is made easy with Buffalo's TS5600DWR.
Hot-swap function enhances data security
With hot-swap functionality, even if a drive fails, the TeraStation 5600 will automatically power down the faulty drive to allow its safe removal and replacement without interrupting work or causing any data loss. -
Business-class features
The Buffalo TeraStation 5600 offers business-class features, such as hot-swappable drives, IP camera recording, support for iSCSI target and fast memory. -
Multiple USB ports
The solution is configured with multiple USB ports for greater flexibility. Use the USB port to add an external hard drive, printer or UPS connectivity.
- BUFFALO TeraStation 5600 DWR - NAS server - 12 TB
- NAS server
- Bundled Services
- 3 years 24-hour TeraStation VIP HDD Exchange Service
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 12 TB
- Max Supported Capacity
- 24 TB
- Installed Devices / Modules Qty
- 6 (installed) / 6 (max)
- 17 cm x 23 cm x 26 cm
- 10 kg ()
- Processor
- 1 x Intel Atom D2700 2.13 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, 50, JBOD, 51
- Hard Drive
- 6 x 2 TB SATA 3Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Linux
- System Requirements
- Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.4 - 10.9, Windows 10
- 3-year warranty
- NAS server
- Bundled Services
- Host Connectivity
- Gigabit Ethernet
- 12 TB
- 24 TB
- 17 cm
- 23 cm
- 26 cm
- 10 kg ()
- Built-in Devices
- Status LCD
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 2 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 51
Hard Drive
- HDD - hot-swap
- Capacity
- 6 x 2 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP, UDP/IP
- Remote Management Protocol
- SNMP, HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, SFTP
- LDAP support, wake on LAN (WOL), DFS support, FTP server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation, SFTP server
- DLNA CERTIFIED
- Expansion Bays
- 6 (total) / 0 (free) x hot-swap
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x serial - DB-9
- Device-to-device data replication, Citrix Ready, VMware Ready
- Power Device
- Internal power supply
- Voltage Required
- 120 Watt
- Linux
- Software Included
- NovaBACKUP Business Essentials (10 licences), SoleraTec Phoenix RSM (1 license), Buffalo Surveillance Server
- OS Required
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
