Buffalo TeraStation 5400R WS5400RR1604S2EU 16TB (4x4TB WD Red) NAS
Quicklinx: B92NWS00 Mfr#: WS5400RR1604S2EU
  • Atom
Buffalo Technology's TeraStation WS5400R rack mount with Windows Storage Server 2012 combines four hard drive, high-performance network attached storage with the power and convenience of Windows operating system.
The WS5400R seamlessly melds with networks' existing Windows computers and server enabling quick straightforward deployment and massive storage capacity available in an instant.
The Buffalo quality you know and trust, plus the power of Windows, gives WS5400R users flexible and fully customisable business-critical support. Once deployed, users will find WS5400R enables full Active Directory integration facilitating comprehensive access management, policies, and security. This allows networks to automate access and manage storage in the same way as they do their Windows Server.
  • Swap function enhances data security
    With hot swap functionality, even if a drive fails, the TeraStation 5400 rackmount WSS will automatically power down the faulty drive to allow its safe removal and replacement without interrupting work or causing any data loss.
  • Business class features
    The Buffalo TeraStation 5400 Rackmount WSS offers business class features such as, hot swap drives, support for ISCI target.
  • Ultra high-speed data transfer with SuperSpeed USB 3.0
    It boosts high-speed data transfer rates up to 5 Gbps on a SuperSpeed USB 3.0 connection.
BUFFALO TeraStation 5400r WSS - NAS server - 16 TB
NAS server
Bundled Services
3 years 24-hour TeraStation VIP HDD Exchange Service
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable
Total Storage Capacity
16 TB
Max Supported Capacity
16 TB
4 (installed) / 4 (max)
42.95 cm x 43 cm x 4.43 cm
9 kg ()
1 x Intel Atom D2700 2.13 GHz (Dual-Core)
Storage Controller
RAID SATA 3Gb/s RAID RAID 0, 1, 5, JBOD
Hard Drive
4 x 4 TB SATA 3Gb/s
10Mb LAN, 100Mb LAN, GigE
RAM
4 GB
Storage Operating System
Microsoft Windows Storage Server 2012 R2 Standard
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X 10.7 or later, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows RT, Microsoft Windows RT 8.1
3-year warranty
NAS server
Bundled Services
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable
16 TB
16 TB
42.95 cm
43 cm
4.43 cm
9 kg ()
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
4 GB DDR3
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, JBOD
Hard Drive
HDD - hot-swap
4 x 4 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP, HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), DFS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
LDAP support, wake on LAN (WOL), print server, Remote Desktop Protocol (RDP) support, Jumbo Frames support, FTP server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation, SFTP server
DLNA CERTIFIED
Expansion Bays
4 (total) / 0 (free) x hot-swap
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x serial - DB-9
Synchronous data mirroring, UPS support, device-to-device data replication
Internal power supply
100 Watt
Software Included
NovaBACKUP Business Essentials (10 licences), Buffalo NAS Navigator
Limited warranty - 3 years
5 °C
20 - 80% (non-condensing)
B92N C2G 5m USB 2.0 A/B Cable - Black In Stock £5.07
