Buffalo Technology's TeraStation WS5400R rack mount with Windows Storage Server 2012 combines four hard drive, high-performance network attached storage with the power and convenience of Windows operating system.
The WS5400R seamlessly melds with networks' existing Windows computers and server enabling quick straightforward deployment and massive storage capacity available in an instant.
The Buffalo quality you know and trust, plus the power of Windows, gives WS5400R users flexible and fully customisable business-critical support. Once deployed, users will find WS5400R enables full Active Directory integration facilitating comprehensive access management, policies, and security. This allows networks to automate access and manage storage in the same way as they do their Windows Server.
Swap function enhances data security
With hot swap functionality, even if a drive fails, the TeraStation 5400 rackmount WSS will automatically power down the faulty drive to allow its safe removal and replacement without interrupting work or causing any data loss. -
Business class features
The Buffalo TeraStation 5400 Rackmount WSS offers business class features such as, hot swap drives, support for ISCI target. -
Ultra high-speed data transfer with SuperSpeed USB 3.0
It boosts high-speed data transfer rates up to 5 Gbps on a SuperSpeed USB 3.0 connection.
- BUFFALO TeraStation 5400r WSS - NAS server - 16 TB
- NAS server
- Bundled Services
- 3 years 24-hour TeraStation VIP HDD Exchange Service
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable
- Total Storage Capacity
- 16 TB
- Max Supported Capacity
- 16 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 42.95 cm x 43 cm x 4.43 cm
- 9 kg ()
- Processor
- 1 x Intel Atom D2700 2.13 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, 5, JBOD
- Hard Drive
- 4 x 4 TB SATA 3Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Microsoft Windows Storage Server 2012 R2 Standard
- System Requirements
- Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X 10.7 or later, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows RT, Microsoft Windows RT 8.1
- 3-year warranty
- NAS server
- Bundled Services
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable
- 16 TB
- 16 TB
- 42.95 cm
- 43 cm
- 4.43 cm
- 9 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 4 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 4 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- SNMP, HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), DFS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- LDAP support, wake on LAN (WOL), print server, Remote Desktop Protocol (RDP) support, Jumbo Frames support, FTP server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation, SFTP server
- DLNA CERTIFIED
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x serial - DB-9
- Synchronous data mirroring, UPS support, device-to-device data replication
- Power Device
- Internal power supply
- Voltage Required
- 100 Watt
- Software Included
- NovaBACKUP Business Essentials (10 licences), Buffalo NAS Navigator
- OS Required
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
