Product
Brand
Buffalo TeraStation 5400 WD Red 12TB NAS
Quicklinx: BK2QWS00 Mfr#: TS5400DWR1204-EU
  • Atom
  • Windows 8 (32/64 bits)
TeraStation 5400 is a high performance 4-drive network storage solution ideal for businesses and demanding users requiring a reliable RAID based NAS and iSCSI storage solution for larger networks and business critical applications. With the powerful Intel Atom processor, and fully populated with high-reliability WD Red hard drives, the TeraStation 5400 provides exceptional performance during file transfers and everyday NAS functions: experience maximum network throughput while a replication job runs in the background, network surveillance video is recording from multiple IP cameras and remote users are accessing content.
BUFFALO TeraStation 5400 - NAS server - 12 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
12 TB
4 (installed) / 4 (max)
17 cm x 23.1 cm x 21.6 cm
8 kg
1 x Intel Atom D2550 1.86 GHz (Dual-Core)
Storage Controller
RAID SATA 3Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
4 x 3 TB SATA 3Gb/s
10Mb LAN, 100Mb LAN, GigE
RAM
2 GB
Storage Operating System
Linux
Microsoft Windows 2000 Server, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows XP Media Center Edition 2005, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.9
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
12 TB
17 cm
23.1 cm
21.6 cm
8 kg
Built-in Devices
Status LCD
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
2 GB DDR3
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
4 x 3 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP, HTTP, HTTPS
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
LDAP support, print server, DFS support, FTP server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation, SFTP server
Expansion Bays
4 (total) / 0 (free) x hot-swap
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x serial - DB-9
Wake on LAN, UPS support, device-to-device data replication
Internal power supply
96 Watt
Linux
Software Included
NovaBACKUP Business Essentials (10 licences), SoleraTec Phoenix RSM (1 license), Buffalo Surveillance Server
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
BK2Q C2G 2m USB 2.0 A/B Cable - Black In Stock £3.08
BK2Q C2G 5m USB 2.0 A/B Cable - Black In Stock £4.39
BK2Q C2G 2-Port USB 2.0 Manual Switch In Stock £17.49
BK2Q C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.21
BK2Q C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.75
BK2Q C2G 12m USB 2.0 A/A Active Extension Cable In Stock £15.46
BK2Q C2G USB 2.0 To Fast Ethernet Adapter In Stock £20.39
