Buffalo Technology's TeraStation WS5400D with Windows Storage Server 2012 combines four hard drive, high-performance network attached storage with the power and convenience of Windows operating system.
- BUFFALO TeraStation 5400 WSS - NAS server - 12 TB
- NAS server
- Bundled Services
- 3 years 24-hour TeraStation VIP HDD Exchange Service
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 12 TB
- Max Supported Capacity
- 12 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 17 cm x 23.1 cm x 21.6 cm
- 8 kg
- Processor
- 1 x Intel Atom D2550 1.86 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s - RAID 0, 1, 5, JBOD
- Hard Drive
- 4 x 3 TB SATA 3Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Microsoft Windows Storage Server 2012 R2 Workgroup
- System Requirements
- Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X 10.7 or later, Windows 8, Microsoft Windows Server 2012, Microsoft Windows RT, Microsoft Windows Server 2012 R2, Windows 8.1, Microsoft Windows RT 8.1
- 3 years warranty
- NAS server
- Bundled Services
- Host Connectivity
- Gigabit Ethernet
- 12 TB
- 12 TB
- 17 cm
- 23.1 cm
- 21.6 cm
- 8 kg
- Built-in Devices
- Status LCD
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 4 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 3 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- SNMP, HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), DFS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- LDAP support, wake on LAN (WOL), print server, Remote Desktop Protocol (RDP) support, Jumbo Frames support, FTP server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation, SFTP server
- DLNA CERTIFIED
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9
- Synchronous data mirroring, UPS support, device-to-device data replication
- Power Device
- Internal power supply
- Voltage Required
- 96 Watt
- Software Included
- NovaBACKUP Business Essentials (10 licences), Buffalo NAS Navigator
- OS Required
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.00 | in stock |
£939.80
saving £2.50
saving £2.50
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.03 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £4.28 |
C2G 2-Port USB 2.0 Manual Switch | In Stock | £16.49 |
C2G 5m USB 2.0 A Male to A Female Active Extension Cable | In Stock | £11.53 |
C2G 4-Port USB 2.0 Aluminum Hub | In Stock | £25.75 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £15.20 |
C2G USB 2.0 To Fast Ethernet Adapter | In Stock | £19.21 |
