Buffalo TeraStation 5200 WS5220DN08W6EU 8TB (2 x 4TB WD Red) TAS
Quicklinx: DKBZWS00 Mfr#: WS5220DN08W6EU
  • Atom
  • Windows 8.1 (32/64 bits)
TeraStation WS5020N6 series is a high-performance network attached storage with the power and convenience of Windows operating system. TeraStation WS5020N6 series features native 10GbE connectivity and achieves increased reliability by populating with hard drives built specifically for always-on NAS devices.
The WS5020N6 seamlessly melds with networks' existing Windows computers and server enabling quick straightforward deployment and massive storage capacity available in an instant. WS5020N6 is an ideal solution for consolidating multiple file servers into a single solution that enables cost reduction and lowering of the overhead on your existing servers for other workloads.
Once deployed, users will find WS5020N6 enables full Active Directory integration facilitating comprehensive access management, policies, and security. This allows networks to automate access and manage storage in the same way as they do their Windows Server. PowerShell and Microsoft Systems Center are ready-to-use, as well as a flexible choice of storage protocols (iSCSI, CIFS/SMB, NFS). Your most demanding applications and processes, such as replication, SQL, a fast-indexing search during an anti-virus scan, and more, are no problem for the WS5020N6.
BUFFALO TeraStation WS5020N6 Series WS5220DN08W6EU - NAS server - 8 TB
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Total Storage Capacity
8 TB
17 cm x 23 cm x 17 cm
5 kg ()
1 x Intel Atom C3338 (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID 1, JBOD
Hard Drive
2 x 4 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE, 10 GigE, 5 GigE, 2.5 GigE
RAM
8 GB
Storage Operating System
Microsoft Windows Storage Server 2016 Workgroup
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Windows 10, Microsoft Windows Server 2016, Apple MacOS X 10.11 - 10.13
3-year warranty
NAS server
Host Connectivity
8 TB
17 cm
23 cm
17 cm
5 kg ()
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
8 GB DDR4
ECC
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 4 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP, UDP/IP, SMB
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), Server Message Block (SMB)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz
Expansion Bays
2 (total) / 0 (free) x hot-swap
2 x USB 3.0 - Type A , 1 x Ethernet 10Gb - RJ-45 , 2 x Ethernet 1000Base-T - RJ-45
LCD display
Internal power supply
28.7 Watt
Power Consumption Stand by
5.2 Watt
Software Included
NAS Navigator2, NovaBACKUP Buffalo Edition (11 licences)
Limited warranty - 3 years
10 - 85% (non-condensing)
