Providing seamless integration with Windows computers and servers, TeraStation 5200 WSS incorporates the powerful dual-core Intel Atom processor, for class-leading performance: experience maximum network throughput while NAS and iSCSI targeting operations run simultaneously. Additionally, support for NTFS for very specific file-level security and native Active Directory support provides integration with large Windows networks. TeraStation 5200 WSS is an economical turnkey solution for highly reliable and continuously available high-performance network storage for a variety of data needs.
- BUFFALO TeraStation 5200 WSS - NAS server - 8 TB
- NAS server
- Bundled Services
- 3 years 24-hour TeraStation VIP HDD Exchange Service
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 8 TB
- Max Supported Capacity
- 8 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 17 cm x 23 cm x 17 cm
- 4.5 kg ()
- Processor
- 1 x Intel Atom D2550 1.86 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 4 TB SATA 3Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Microsoft Windows Storage Server 2012 R2 Workgroup
- System Requirements
- Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X 10.7 or later, Windows 8, Microsoft Windows Server 2012, Windows 8.1 RT, Microsoft Windows Server 2012 R2, Windows 8.1, Windows RT
- 3-year warranty
- NAS server
- Bundled Services
- Host Connectivity
- Gigabit Ethernet
- 8 TB
- 8 TB
- 17 cm
- 23 cm
- 17 cm
- 4.5 kg ()
- Built-in Devices
- Status LCD
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 4 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 4 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- SNMP, HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), DFS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- LDAP support, wake on LAN (WOL), print server, Remote Desktop Protocol (RDP) support, Jumbo Frames support, FTP server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation, SFTP server
- DLNA CERTIFIED
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9
- Synchronous data mirroring, UPS support, device-to-device data replication
- Power Device
- Internal power supply
- Voltage Required
- 47 Watt
- Software Included
- NovaBACKUP Business Essentials (10 licences), Buffalo NAS Navigator
- OS Required
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
