Buffalo's new TeraStation enclosure (TS4800D-EU) joins Buffalo's TeraStation family with customizable Network Attached Storage with greater flexibility - users can start by installing one drive and add up to seven additional drives as storage and back-up requirements grow.
TeraStation 4800 is equipped with the powerful Intel Atom D2700 Dual-Core Processor and will impress users with both faster transfer of large files and faster file access from multiple computers. Its top-of-class performance is perfect for demanding small, medium, and growing businesses.
When populated with two or more drives the TeraStation 4800 protects your data with RAID and hot swap functionality allows users to change disks without downtime. Another added bonus: the new TeraStation enclosure also comes with 10 free NovaStor NovaBACKUP licenses.
The TS4800 also provides important features to support your business such as Active Directory support, IP camera recording, iSCSI target, a faster and easy-to-use interface, and 2GB of fast DDR3 memory installed. All of this, together with two Gigabit Ethernet ports, two super speed USB 3.0 ports and two high speed USB 2.0 ports, gives users a fast, versatile, and feature-rich NAS enclosure. Buffalo's TS4800D-EU enclosure is compatible with 1, 2, 3, and 4TB drives (sold separately).
Intel Atom D2700 dual-core processor
TeraStation 4800 is equipped with the powerful Intel Atom D2700 dual-core processor and will impress users with both faster transfer of large files and faster file access from multiple computers. Its top-of-class performance is perfect for demanding small, medium, and growing businesses. -
Data backup with replication
The backup replication function allows data replication connected via a LAN port, enabling it to become a spare drive. Having the mirrored unit as a spare drive improves reliability, fault tolerance, and accessibility, and quickens recovery from any hard drive failure. -
Hot swap function for added data security
With RAID 1 (full redundancy) and hot swap functionality enabled, even if a drive fails, the TeraStation 4800 will automatically power down the faulty drive to allow its safe removal and replacement without causing any data loss or down time. -
Ultra high-speed data transfer with SuperSpeed USB 3.0
The TeraStation 4800 supports SuperSpeed USB 3.0 connectivity which dramatically increases data transfer rates up to 5 Gbps. -
Backup
TeraStation 4800 is bundled with 10 licenses of NovaBACKUP business essentials, providing a complete, all-in-one data protection solution for small and medium businesses serious about protecting digital assets. Back up PCs, storage servers, exchange servers and SQL databases. -
Remote web access
Remotely access the TeraStation 4800 from anywhere, via a desktop, smartphone, tablet or over the Internet with Buffalo's unique Web Access technology.
- BUFFALO TeraStation 4800 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Max Supported Capacity
- 32 TB
- Installed Devices / Modules Qty
- 0 (installed) / 8 (max)
- 30 cm x 21.5 cm x 23 cm
- 6.9 kg ()
- Processor
- 1 x Intel Atom D2700 (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, 50, JBOD, 60, 51, 61
- Hard Drive
- SATA 3Gb/s - Full-Automatic Encryption
- Networking
- Network adapter 10Mb LAN, 100Mb LAN, GigE
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.8
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 32 TB
- 30 cm
- 21.5 cm
- 23 cm
- 6.9 kg ()
- Built-in Devices
- Status LCD
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 2 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60, RAID 51, RAID 61
Hard Drive
- HDD - hot-swap
- Interface Type
- SATA 3Gb/s
- Network adapter
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- TCP/IP
- Remote Management Protocol
- SNMP, HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- LDAP support, DFS support, Buffalo Web Access, Direct Copy, Apple Time Machine compatible, NTP time synchronisation
- Expansion Bays
- 8 (total) / 8 (free) x hot-swap
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x serial - DB-9
- Device-to-device data replication
- Power Device
- Internal power supply
- Voltage Required
- 110 Watt
- Software Included
- NovaBACKUP Business Essentials (10 licences), SoleraTec Phoenix RSM (1 license), Buffalo Surveillance Server
- OS Required
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
