Your basket is empty
Buffalo TeraStation 4400R/8TB (4 x 2TB WD RED HDDs) 4 Bay 1U NAS
Quicklinx: BVQYWS00 Mfr#: TS4400R/8TB-RED
  • Atom
  • Windows 8 (32/64 bits)
Buffalo's TeraStation rackmount enclosure joins Buffalo's TeraStation family with customizable network attached storage with greater flexibility - users can start by installing one drive and add up to three additional drives as storage and back-up requirements grow.
TeraStation 4400R is equipped with the powerful Intel processor and will impress users with both faster transfer of large files and faster file access from multiple computers. Its top-of-class performance is perfect for demanding small, medium, and growing businesses
When populated with two or more drives the TeraStation 4400R protects your data with RAID and hot swap functionality allows users to change disks without downtime.
The TS4400R also provides important features to support your business such as active directory support, IP camera recording, iSCSI target, a faster and easy-to-use interface, and 2 GB of fast DDR3 memory installed.
BUFFALO TeraStation 4400R - NAS server - 8 TB
NAS server
Bundled Services
3 years 24-hour TeraStation VIP HDD Exchange Service
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable
Total Storage Capacity
8 TB
4 (installed) / 4 (max)
43 cm x 42 cm x 4.43 cm
6.2 kg
1 x Intel Atom D2701 2.13 GHz (Dual-Core)
Storage Controller
RAID SATA 3Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
4 x 2 TB SATA 6Gb/s - Full-Automatic Encryption
10Mb LAN, 100Mb LAN, GigE
RAM
2 GB
Storage Operating System
Linux
Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.8
3 years warranty
NAS server
Bundled Services
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable
8 TB
43 cm
42 cm
4.43 cm
6.2 kg
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
2 GB DDR3
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap - 3.5"
4 x 2 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP, HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), DFS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
LDAP support, wake on LAN (WOL), print server, FTP server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation, SFTP server
DLNA CERTIFIED
Expansion Bays
4 (total) / 0 (free) x hot-swap - 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9
Device-to-device data replication
Internal power supply
96 Watt
Linux
Software Included
NovaBACKUP Business Essentials (10 licences), SoleraTec Phoenix RSM (1 license), Buffalo Surveillance Server
Limited warranty - 3 years
5 °C
20 - 80% (non-condensing)
