Product
Buffalo TeraStation 4400R - 4 Bay Rackmount Diskless Enclosure NAS
Quicklinx: 9257WS00 Mfr#: TS4400R-EU
  • Atom
  • Windows 8 (32/64 bits)
Buffalo's new TeraStation rackmount enclosure (TS4400R-EU) joins Buffalo's TeraStation family with customizable Network Attached Storage with greater flexibility - users can start by installing one drive and add up to three additional drives as storage and back-up requirements grow.
TeraStation 4400R is equipped with the powerful Intel Atom D2700 Dual-Core Processor and will impress users with both faster transfer of large files and faster file access from multiple computers. Its top-of-class performance is perfect for demanding small, medium, and growing businesses.
When populated with two or more drives the TeraStation 4400R protects your data with RAID and hot swap functionality allows users to change disks without downtime. Another added bonus: the new TeraStation enclosure also comes with 10 free NovaStor NovaBACKUP licenses.
The TS4400R also provides important features to support your business such as Active Directory support, IP camera recording, iSCSI target, a faster and easy-to-use interface, and 2GB of fast DDR3 memory installed. All of this, together with two Gigabit Ethernet ports, two super speed USB 3.0 ports and two high speed USB 2.0 ports, gives users a fast, versatile, and feature-rich NAS enclosure. Buffalo's TS4400R-EU enclosure is compatible with 1, 2, 3, and 4TB drives (sold separately).
BUFFALO TeraStation 4400R - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable
Total Storage Capacity
0 GB
Max Supported Capacity
16 TB
0 (installed) / 4 (max)
43 cm x 42 cm x 4.43 cm
6.2 kg
1 x Intel Atom D2700 (Dual-Core)
Storage Controller
RAID SATA 3Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
SATA 3Gb/s - Full-Automatic Encryption
Network adapter 10Mb LAN, 100Mb LAN, GigE
RAM
2 GB
Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.8
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable
0 GB
16 TB
43 cm
42 cm
4.43 cm
6.2 kg
Built-in Devices
Status LCD
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
2 GB DDR3
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
Interface Type
SATA 3Gb/s
Network adapter
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP, HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
LDAP support, DFS support, Buffalo Web Access, Direct Copy, Apple Time Machine compatible, NTP time synchronisation
Expansion Bays
4 (total) / 4 (free) x hot-swap
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9
Device-to-device data replication
Internal power supply
96 Watt
Software Included
NovaBACKUP Business Essentials (10 licences), SoleraTec Phoenix RSM (1 license), Buffalo Surveillance Server
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
9257 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.10
9257 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.49
9257 C2G 2-Port USB 2.0 Manual Switch In Stock £17.50
9257 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.23
9257 C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
9257 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.33
