Buffalo's TeraStation enclosure (TS4200D-EU) joins Buffalo's TeraStation family with customisable network attached storage with greater flexibility - users can start by installing one drive and add another drive as storage and back-up requirements grow.
TeraStation 4200 is equipped with the powerful Intel Atom D2550 dual-core processor and will impress users with both faster transfer of large files and faster file access from multiple computers. Its top-of-class performance is perfect for demanding small, medium, and growing businesses.
When populated with two drives the TeraStation 4200 protects your data with RAID and hot swap functionality allows users to change disks without downtime.
- BUFFALO TeraStation 4200D - NAS server - 8 TB
- NAS server
- Bundled Services
- 3 years 24-hour TeraStation VIP HDD Exchange Service
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 8 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 17 cm x 23 cm x 17 cm
- 3.15 kg ()
- Processor
- 1 x Intel Atom D2550 1.86 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 4 TB SATA 3Gb/s - Full-Automatic Encryption
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Linux
- System Requirements
- Microsoft Windows 2000, Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows XP Media Center Edition 2005, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1, Apple MacOS X 10.4 - 10.9
- 3-year warranty
- NAS server
- Bundled Services
- Host Connectivity
- Gigabit Ethernet
- 8 TB
- 17 cm
- 23 cm
- 17 cm
- 3.15 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 2 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 2 x 4 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- SNMP, HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), DFS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- LDAP support, wake on LAN (WOL), print server, FTP server, Buffalo Web Access, BitTorrent Client, Direct Copy, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation, SFTP server
- DLNA CERTIFIED
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9
- Device-to-device data replication
- Power Device
- Internal power supply
- Voltage Required
- 86 Watt
- Linux
- Software Included
- NovaBACKUP Business Essentials (10 licences), SoleraTec Phoenix RSM (1 license), Buffalo Surveillance Server
- OS Required
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
