The TeraStation 3410 series is a high-performance, cost-effective 4-bay Network Attached Storage (NAS) solution, ideal for small businesses and demanding small office and home office (SOHO) users. With a powerful Annapurna Labs Alpine AL-212 1.4 GHz dual-core processor, it provides speedy transfer rates and stable operation during heavy-load work tasks. The robust central processing unit (CPU) and 1 GB of DDR3 RAM means it can run multiple services simultaneously. This allows businesses to focus on concurrent tasks with minimal performance degradation.
NAS HDD inside
Equipped with NAS HDD for high performance and high reliability in NAS and RAID environments. -
Powered by the Annapurna Labs Alpine AL-212 Dual-Core processor
With a processor speed of 1.4 GHz, it guarantees the transfer of large files and faster file access from multiple computers. -
DDR3 memory
1GB of fast DDR3 memory installed. -
iSCSI target support
Works simultaneously as NAS and iSCSI target. -
Replication with TeraStation
Replication is synchronizing a folder on two separate TeraStations in almost real time. It works in only one way - not bi-directional, from source to destination. It is possible to set-up the function in LAN and WAN. The WAN setup includes the remote connection using port forwarding and a VPN setup.
- BUFFALO TeraStation 3410DN - NAS server - 4 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 4 TB
- Max Supported Capacity
- 16 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 17 cm x 23 cm x 21.5 cm
- 7 kg ()
- Localisation
- Europe
- Processor
- 1 x Annapurna Labs Alpine AL-212 1.4 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 4 x 1 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 1 GB
- Power
- AC 100 - 240 V (50/60 Hz)
- Storage Operating System
- Linux
- System Requirements
- Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.9 or later, Windows 10
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 4 TB
- 16 TB
- 17 cm
- 23 cm
- 21.5 cm
- 7 kg ()
- Localisation
- Europe
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 1 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 1 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- SNMP, HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, SFTP
- Buffalo Web Access, Apple Time Machine compatible, Dropbox support, Amazon Cloud Drive support
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), key lock, built-in cooling fan
- Security Slot Type
- Kensington security slot
- Included Accessories
- Front panel key
- Power Device
- Internal power supply
- Voltage Required
- 85 Watt
- Linux
- Software Included
- NAS Navigator2, NovaBACKUP Buffalo Edition (11 licences)
- OS Required
- Limited warranty - 3 years , Limited warranty - parts - hard drive - 3 years - shipment - response time: 24 hours , Technical support - 3 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
