Product
Buffalo TeraStation 3410 16TB NAS HDD 4x4TB 2x1GbE RAID 0/1/5/6/10
Reduced Price - Whilst Stocks Last!
Quicklinx: CJSKWS00 Mfr#: TS3410DN1604-EU
Select:
The TeraStation 3410 series is a high-performance, cost-effective 4-bay Network Attached Storage (NAS) solution, ideal for small businesses and demanding small office and home office (SOHO) users. With a powerful Annapurna Labs Alpine AL-212 1.4 GHz dual-core processor, it provides speedy transfer rates and stable operation during heavy-load work tasks. The robust central processing unit (CPU) and 1 GB of DDR3 RAM means it can run multiple services simultaneously. This allows businesses to focus on concurrent tasks with minimal performance degradation.
  • NAS HDD inside
    Equipped with NAS HDD for high performance and high reliability in NAS and RAID environments.
  • Powered by the Annapurna Labs Alpine AL-212 Dual-Core processor
    With a processor speed of 1.4 GHz, it guarantees the transfer of large files and faster file access from multiple computers.
  • DDR3 memory
    1GB of fast DDR3 memory installed.
  • iSCSI target support
    Works simultaneously as NAS and iSCSI target.
  • Replication with TeraStation
    Replication is synchronizing a folder on two separate TeraStations in almost real time. It works in only one way - not bi-directional, from source to destination. It is possible to set-up the function in LAN and WAN. The WAN setup includes the remote connection using port forwarding and a VPN setup.
BUFFALO TeraStation 3410DN - NAS server - 16 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
16 TB
Max Supported Capacity
16 TB
4 (installed) / 4 (max)
17 cm x 23 cm x 21.5 cm
7 kg
Europe
1 x Annapurna Labs Alpine AL-212 1.4 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
4 x 4 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
RAM
1 GB
AC 100 - 240 V (50/60 Hz)
Storage Operating System
Linux
Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.9 or later, Windows 10
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
16 TB
16 TB
17 cm
23 cm
21.5 cm
7 kg
Europe
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
4 x 4 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP, HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, SFTP
Buffalo Web Access, Apple Time Machine compatible, Dropbox support, Amazon Cloud Drive support
Expansion Bays
4 (total) / 0 (free) x hot-swap
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A
1 x network cable
Security lock slot (cable lock sold separately), key lock, built-in cooling fan
Security Slot Type
Kensington security slot
Front panel key
Internal power supply
85 Watt
Linux
Software Included
NAS Navigator2, NovaBACKUP Buffalo Edition (11 licences)
Limited warranty - 3 years , Limited warranty - parts - hard drive - 3 years - shipment - response time: 24 hours , Technical support - 3 years
10 - 85% (non-condensing)
