The TeraStation 3210 series is a high-performance, cost-effective 2-bay Network Attached Storage (NAS) solution, ideal for small businesses and demanding small office and home office (SOHO) users. With a powerful Annapurna Labs Alpine AL-212 1.4 GHz dual-core processor, it provides speedy transfer rates and stable operation during heavy-load work tasks. The robust central processing unit (CPU) and 1 GB of DDR3 RAM means it can run multiple services simultaneously.
Powered by the Annapurna Labs Alpine AL-212 Dual-Core processor
With a processor speed of 1.4 GHz, it guarantees the transfer of large files and faster file access from multiple computers. -
DDR3 memory
1GB of fast DDR3 memory installed. -
NAS HDD inside
Equipped with NAS HDD for high performance and high reliability in NAS and RAID environments. -
iSCSI target support
Works simultaneously as NAS and iSCSI target. -
Replication with TeraStation
Replication is synchronizing a folder on two separate TeraStations in almost real time. It works in only one way - not bi-directional, from source to destination. It is possible to set-up the function in LAN and WAN. The WAN setup includes the remote connection using port forwarding and a VPN setup.
- BUFFALO TeraStation 3210DN - NAS server - 2 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 2 TB
- Max Supported Capacity
- 8 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 17 cm x 23 cm x 17 cm
- 4.8 kg
- Localisation
- Europe
- Processor
- 1 x Annapurna Labs Alpine AL-212 1.4 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s - RAID 0, 1, JBOD
- Hard Drive
- 2 x 1 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 1 GB
- Power
- AC 100 - 240 V (50/60 Hz)
- Storage Operating System
- Linux
- System Requirements
- Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.9 or later, Windows 10
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 2 TB
- 8 TB
- 17 cm
- 23 cm
- 17 cm
- 4.8 kg
- Localisation
- Europe
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 1 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 1 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- SNMP, HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, SFTP
- Buffalo Web Access, Apple Time Machine compatible, Dropbox support, Amazon Cloud Drive support
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), key lock, built-in cooling fan
- Security Slot Type
- Kensington security slot
- Included Accessories
- Front panel key
- Power Device
- Internal power supply
- Voltage Required
- 85 Watt
- Linux
- Software Included
- NAS Navigator2, NovaBACKUP Buffalo Edition (11 licences)
- OS Required
- Limited warranty - 3 years , Limited warranty - parts - hard drive - 3 years - shipment - response time: 24 hours , Technical support - 3 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
