Buffalo Technology's TeraStation 1400 series is a four bay storage solution with advanced business features and a strong dual issue CPU: perfect for SMB users in need of extra-large capacity and ready to migrate to network attached storage or expand the capacity and features of their existing storage solution. Users will be impressed with the TS1400D for its business-class feature set. The TS1400D is ready for intensive data storage tasks and is equipped with powerful processor with DDR3 RAM bringing together Buffalo's high performance hardware and architecture and delivering them in a cost-effective solution.
Business class features
The Buffalo TeraStation 1400 offers business class features such as data encryption and fast DDR3 memory. -
Swap function enhances data security
With Hot Swap functionality, even if a drive fails, the TeraStation 1400 will automatically power down the faulty drive to allow its safe removal and replacement without interrupting work or causing any data loss.
- BUFFALO TeraStation 1400 - NAS server - 12 TB
- NAS server
- Bundled Services
- 3 years 24-hour TeraStation VIP HDD Exchange Service
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 12 TB
- Max Supported Capacity
- 16 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 17.7 cm x 22.7 cm x 12.75 cm
- 5.4 kg ()
- Processor
- 1 x Marvell ARMADA 370 1.2 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 4 x 3 TB SATA 3Gb/s - Full-Automatic Encryption
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 512 MB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Linux
- System Requirements
- Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Microsoft Windows RT 8.1, Apple MacOS X 10.4 - 10.9
- 3-year warranty
- NAS server
- Bundled Services
- Host Connectivity
- Gigabit Ethernet
- 12 TB
- 16 TB
- 17.7 cm
- 22.7 cm
- 12.75 cm
- 5.4 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 3 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- LDAP support, FTP server, Buffalo Web Access, Apple Time Machine compatible, NTP time synchronisation, SFTP server
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 2 x USB 3.0 - Type A
- Device-to-device data replication
- Power Device
- External power adapter
- Voltage Required
- 28 Watt
- Linux
- Software Included
- NovaBACKUP Business Essentials (10 licences)
- OS Required
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.02 |
