Buffalo’s MiniStation™ Safe (HD-PNFU3 series) is a slim, SuperSpeed USB 3.0, portable hard drive that comes in a patented shock-proof chassis and features Buffalo’s new Lock-and-Go feature – thereby protecting your data in two important ways!
Lock and go
Buffalo gave the HD-PNFU3 a sleek design with an attractive matte finish and Buffalo's shock-proof chassis. -
A small, attractive, and secure package
Buffalo's MiniStation Safe occupies minimal space and offers USB 3.0 bus-powered mobile storage for your data and for your on-the-go lifestyle. It works with PC and Mac, so you can access your files from whichever computer you are on, even while on the go.
- BUFFALO MiniStation Safe (HD-PNFU3 series) - hard drive - 3 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 3 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Shock resistant, Bus Powered by USB, software encryption, power management support, Lock-and-Go Security, 256-bit AES, 128-bit AES
- Power Source
- USB bus
- Enclosure Colour
- Black
- 79.5 mm x 115 mm x 21.5 mm
- 240 g
- 2-year warranty
- Capacity
- 3 TB
- Interface
- USB 3.0
- 79.5 mm
- 115 mm
- 21.5 mm
- 240 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Power Source
- USB bus
- Software Included
- SecureLockMobile, Buffalo Tools eco Manager
- OS Required
- Microsoft Windows Vista, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 or later, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10
- Cables Included
- 1 x USB 3.0 cable
- Plug and Play
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
