FAST AND SLIM PORTABLE SSD
Buffalo’s MiniStation SSD Velocity is the ideal external storage device for users seeking additional storage with extremely fast transfer rates in a slim design. Only 8.8 mm in thickness, the elegant aluminum chassis is the slimmest portable SSD of its class. MiniStation SSD Velocity’s "Read" performance can reach outstanding rates of above 500MB/s and "Write" performance above 480MB/s.
Compact and Lightweight
The lightweight metal chassis saves space for ultimate portability with a stylish and sophisticated design. Available in Silver or Black.
USB 3.1 (Gen 2)
Native USB 3.1 (Gen 2) with support for legacy USB 2.0 and SuperSpeed 3.0.
Buffalo Tools
Comes with Buffalo Tools such as eco manager and Secure Lock Mobile ( for Windows) and Buffalo’s Backup Utility that automatically backs up your Windows PC, protecting your data.
Backup for multiple Mac computers
Supports Apple Time Machine -- for backing up multiple Mac computers
- USB 3.1 Gen2 interface
- Available in capacities of 240GB, 480GB, 960GB
- Slim design with measurements of 115 x 79 x 8.8 mm
- Shock resistance
- Software encryption
- Extra-long Type A and Type C USB cables in the box
- Bus powered – No additional power input required
- Compact aluminum body, available in black and silver
- BUFFALO MiniStation SSD-PUSU3 - SSD - 480 GB - USB 3.1 Gen 2
- Solid state drive - external (portable)
- Capacity
- 480 GB
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Interface
- USB 3.1 Gen 2
- Data Transfer Rate
- 10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Shock resistant, Bus Powered by USB, Apple Time Machine compatible, software encryption
- Power Source
- USB bus
- Enclosure Colour
- Silver
- 79 mm x 115 mm x 8.8 mm
- 100 g
- 2-year warranty
- Capacity
- 480 GB
- Interface
- USB 3.1 Gen 2
- Internal Drive Interface
- SATA 6 Gb/s
- 79 mm
- 115 mm
- 8.8 mm
- 100 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 500 MB/s
Expansion & Connectivity
- 1 x USB 3.1 Gen 1 - 10 pin Micro-USB Type B
- Power Source
- USB bus
- Software Included
- Disk Formatter 2, SecureLockMobile 2
- OS Required
- Apple MacOS X 10.9 or later, Microsoft Windows 7 / 8.1 / 10
- Cables Included
- 1 x USB 3.1 cable - USB Type A to micro-B - external - 45 cm , 1 x USB 3.1 cable - USB-C to micro-B - external - 45 cm
- Enclosure Material
- Aluminium
- Enclosure Colour
- Silver
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 10 - 85% (non-condensing)
