Buffalo MiniStation Extreme Water&Dust Resistant USB 3.0 2TB - Black
Quicklinx: BK4CWS00 Mfr#: HD-PZF2.0U3B-EU
BUFFALO's MiniStation Extreme offers high performance USB3.0 portable storage in a compact and sophisticated design. The internal hard drive is encased in a highly shock-resistant body with rubberized elements to protect it from accidental bumps.
  • US military grade (MIL-SPEC) shock protection
    Shock absorbers surround the hard disk protecting it from damage and drops from up to 2 meters.
  • Flex connect USB cable
    Removable, integrated USB cable snaps to chassis for improved portability.
  • Hardware disk encryption
    Automatic 256-bit AES Full Disk Encryption (FDE) protects your data from unauthorized access.
  • Compact and sleek
    Slim, lightweight chassis saves space for ultimate portability.
  • USB powered
    Perfect companion for your laptop or netbook - no external power supply needed.
  • Connect and go
    Preformatted hard drive is ready for immediate use with Windows and Mac.
  • Buffalo tools
    A feature-rich software suite of tools designed to boost PC performance.
  • Back up your files
    Bu ffalo's backup utility automatically backs up your Windows PC, protecting your data.
  • Time Machine compatibility
    Works perfectly with Time Machine to back up your Mac computer.
  • Eco manager
    Eco minded power management tool regulates power usage, conserving energy and battery consumption.
BUFFALO MiniStation Extreme - hard drive - 2 TB - USB 3.0
Hard drive - external (portable)
2 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Shock resistant, water resistant, Hardware Full Disk Encryption (FDE), dust-proof, wrap-around USB cable, Apple Time Machine compatible, 256-bit AES
Power Source
USB bus
Enclosure Colour
9 cm x 14.1 cm x 2.1 cm
277 g
2 TB
Hardware Encryption
USB 3.0
Internal Drive Interface
SATA 3 Gb/s
9 cm
14.1 cm
2.1 cm
277 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
USB bus
Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.7 or later, Windows 8, Windows 8.1 RT, Windows 8.1, Windows RT
1 x USB 3.0 cable - integrated
MIL-STD 810G 516.6, IP5X, IPX3
Enclosure Colour
5 °C
35 °C
20 - 80% (non-condensing)
