Your basket is empty
Buffalo MiniStation Extreme Water&Dust Resistant USB 3.0 1TB - Silver
Quicklinx: BK4BWS00 Mfr#: HD-PZF1.0U3S-EU
Form Factor: 2.5"
Capacity: 1TB
Interface: USB 3.0
5 in stock
£64.79 ex VAT
£77.74 inc VAT
Standard delivery Delivered within 3-5 working days
BUFFALO's MiniStation Extreme offers high performance USB3.0 portable storage in a compact and sophisticated design. The internal hard drive is encased in a highly shock-resistant body with rubberized elements to protect it from accidental bumps.
BUFFALO MiniStation Extreme - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Shock resistant, water resistant, Hardware Full Disk Encryption (FDE), dust-proof, wrap-around USB cable, Apple Time Machine compatible, 256-bit AES
Power Source
USB bus
Enclosure Colour
Silver
9 cm x 14.1 cm x 2.1 cm
277 g
2 years warranty
1 TB
Hardware Encryption
USB 3.0
Internal Drive Interface
SATA 3 Gb/s
9 cm
14.1 cm
2.1 cm
277 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
USB bus
Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.7 or later, Windows 8, Microsoft Windows RT, Windows 8.1 RT, Windows 8.1
1 x USB 3.0 cable - integrated
MIL-STD 810G 516.6, IP5X, IPX3
Enclosure Colour
Silver
5 °C
35 °C
20 - 80% (non-condensing)
Form Factor: 2.5"
Capacity: 1TB
Interface: USB 3.0
Brand: Buffalo
Price Range Ex VAT: 50 - 100
