Your basket is empty
Buffalo LinkStation 410 2TB 1-Bay High Speed NAS
Quicklinx: 8TLPWS00 Mfr#: LS410D0201-EU
Capacity: 2TB
Interface: Gigabit Ethernet
Type: 1-Bay
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£125.73 ex VAT
£150.87 inc VAT
Express delivery Order within the next 17 hours for delivery tomorrow
Buffalo's new LinkStation has the latest CPU with a new generation CPU core for noticeably improved performance that delivers transfer speeds up to 100MB/s!
BUFFALO LinkStation 410 - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
Max Supported Capacity
4 TB
4.5 cm x 20.5 cm x 12.8 cm
1.3 kg
1 x Marvell ARMADA 370 1.2 GHz (Dual-Core)
Storage Controller
SATA SATA 3Gb/s
Hard Drive
1 x 2 TB SATA 3Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
4 TB
4.5 cm
20.5 cm
12.8 cm
1.3 kg
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM Installed
512 MB DDR3
Storage Controller
SATA
Interface Type
SATA 3Gb/s
Hard Drive
HDD
1 x 2 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP
Remote Management Protocol
HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Print server, iTunes server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED, UPnP
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
X external power adapter
24 Watt
Software Included
NovaBACKUP Workstation - Buffalo Edition (5 licences)
5 °C
35 °C
20 - 80% (non-condensing)
Buffalo LinkStation 410 2TB 1-Bay High Speed NAS Bundle deal on Buffalo LinkStation 410 2TB 1-Bay High Speed NAS
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.39 | in stock
£128.43
saving £2.70
8TLP C2G 2m USB 2.0 A/B Cable - Black In Stock £3.17
8TLP C2G 5m USB 2.0 A/B Cable - Black In Stock £4.42
8TLP C2G 2-Port USB 2.0 Manual Switch In Stock £16.84
8TLP C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.23
8TLP C2G 4-Port USB 2.0 Aluminum Hub In Stock £22.62
8TLP C2G 12m USB 2.0 A/A Active Extension Cable In Stock £15.44
8TLP C2G USB Superbooster Extender Kit In Stock £31.09
8TLP C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £31.65
Capacity: 2TB
Type: 1-Bay
Brand: Buffalo
Price Range Ex VAT: 100 - 150
