Buffalo LinkStation 220 Series 8TB (2 x 4TB) 2-Bay NAS
Quicklinx: 9FH2WS00 Mfr#: LS220D0802-EU
Capacity: 8TB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
Type: 2-Bay
  • Windows 8.1 (32/64 bits)
£220.84 ex VAT
£265.00 inc VAT
Room to Spare and Access from Anywhere
Buffalo Technology's LinkStation (LS220D series) combines an incredibly easy User Interface with the convenience, security and capacity of dual-bay, RAID-ready Network Attached Storage.
The LS220D is affordable, fast, and primed for intensive data storage tasks. It's pre-configured and can even be set up via Smartphones with a new mobile optimized and intuitive interface. And with two hard drives users can choose RAID 0 for enhanced performance or RAID 1 for mirroring as part of a backup solution. The LS220D comes with Buffalo's free personal private cloud: wherever you are, all your data is accessible from any web browser or via Buffalo's WebAccess Apps for Android, iOS, or Windows Phone. And with Buffalo's Private Cloud solution users' data stays protected in the physical location of the device - not off-site in a third party's data center.
Buffalo's new LinkStation can also stream up to 4 HD films simultaneously allowing each family member to watch their favorite film, on their own device, at the same time. The LS220 is DLNA and Twonky Beam-ready and can also stream high-end DSD audio files without losing quality.
Buffalo Technology's LS220 series is a two bay Network Attached Storage device available as a diskless enclosure, or fully populated with 2, 4, 6, or 8TB capacity.
Sorry NSA - The Truly Private Cloud
Buffalo's Private Cloud solution ensures your privacy and comes without any monthly fees. With a private cloud users' data stays protected in the physical location of your device - not off-site in a third party's data centre. And with Buffalo's free mobile and tablet Apps, or any web browser, your data is accessible and just a couple keystrokes away.
  • Big capacity
  • No size limitation for each file
  • No transfer size limitation per day
WebAccess - Free Apps and One-click Access from Anywhere
While on the go, Buffalo's free WebAccess service allows users to create a private cloud for easy remote access and file sharing with anyone, anywhere over the Internet. All you need is a Smartphone or tablet and Buffalo's free iOS, Windows or Android app to enjoy full access to the digital assets you keep on your LinkStation™ 220.
A brand new UI has been designed to provide users one-click access to their most commonly accessed settings.
Easily open Linkstation™ files from a remote site or with free WebAccess Apps available for:
  • iOS 4.3 and higher
  • Android 2.3 and higher
  • Windows Mobile 7.5 , 7.8, 8
  • Windows Tablet and Desktop/Laptop with Windows 8
Easy Set up from your Mobile Device!
You can set up your LinkStation 200 in three easy steps with our free "Smart Navigator" App:
  • Plug in your power cable and connect your LinkStation 200 to your router (using the cables provided)
  • Download the "Smart Navigator" from your App Store and follow the simple instructions
  • Save your data and access it from anywhere
Organize Your Life
Ideal for home users, the new LinkStation 220 Series provides simple network storage and backup and offers an assortment of features, allowing users to store, organize, access and stream media files from any computer, smartphone or tablet.
Buffalo's new LinkStation™ can also stream up to 4 HD films simultaneously allowing each family member to watch their favourite film, on their own device, at the same time. The LS220 is DLNA and Twonky Beam-ready and can also stream high-end DSD audio files without losing quality.
Back up
Provides simple and secure shared storage and backup for all PC and Mac computers and mobile devices on a home network. Allows users to backup content on up to five home or office Windows PCs by using Award-winning NovaBACKUP®, or back up Mac computers with Time Machine®: ready for multi-client backups.
BUFFALO LinkStation 220 - NAS server - 8 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
8 TB
Max Supported Capacity
8 TB
2 (installed) / 2 (max)
8.7 cm x 20.5 cm x 12.6 cm
1.7 kg
1 x Marvell ARMADA 370 800 MHz (Dual-Core)
Storage Controller
RAID SATA 3Gb/s - RAID 0, 1, JBOD
Hard Drive
2 x 4 TB SATA 3Gb/s
10Mb LAN, 100Mb LAN, GigE
RAM
256 MB
Microsoft Windows XP, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows XP Media Center Edition 2005, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8, Android 2.3 or later, Microsoft Windows Server 2012 (32/64-bits), Apple iOS 5.0 or later, Windows 8.1 (32/64 bits), Windows 8.1 RT, Windows Phone 8
2 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
8 TB
8 TB
8.7 cm
20.5 cm
12.6 cm
1.7 kg
Enclosure Colour
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
256 MB DDR3
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - 2.5" / 3.5" shared
2 x 4 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP, Bonjour
Remote Management Protocol
HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Print server, iTunes server, FTP server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
Expansion Bays
2 (total) / 0 (free) x internal
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
External power adapter
19 Watt
Software Included
NovaBACKUP Workstation - Buffalo Edition (5 licences)
5 °C
35 °C
20 - 80% (non-condensing)
9FH2 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.90
9FH2 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.05
9FH2 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.83
9FH2 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.66
9FH2 C2G USB Superbooster Extender Kit In Stock £37.61
9FH2 C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.49
9FH2 C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
Capacity: 8TB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Type: 2-Bay
Brand: Buffalo
Price Range Ex VAT: 150 - 300
