Buffalo LinkStation 220 2TB NAS
Quicklinx: F1PKWS00 Mfr#: LS220DR0202-EU
Capacity: 2TB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
29 in stock
£152.34 ex VAT
£182.80 inc VAT
Buffalo's LinkStation LS220DR for the digital home combines an incredibly easy User Interface with the convenience, security and capacity of dual-bay, RAID-ready Network Attached Storage (NAS). It is the only LinkStation that comes populated with WD Red hard drives optimized for RAID and NAS environments.
The LS220DR is affordable, fast, and primed for intensive data storage tasks. It's pre-configured and can even be set up via Smartphones with a mobile-optimized and intuitive interface. And with two hard drives users can choose RAID 0 for enhanced performance or RAID 1 for mirroring as part of a backup solution.
The LS220DR comes with Buffalo's free personal private cloud: Wherever you are, all your data is accessible from any web browser or via Buffalo's WebAccess Apps for Android, iOS, or Windows Phone. And with Buffalo's Private Cloud solution users' data stays protected in the physical location of the device - not off-site in a third party's data center.
The 2-bay NAS can also stream up to 4 HD films simultaneously allowing each family member to watch their favorite film, on their own device, at the same time. The LS220 is DLNA and Twonky Beam-ready and can also stream high-end DSD audio files without losing quality.
  • This cloud is purely private
    Protect your privacy with no monthly fees. Set up LinkStation wherever you want and store your data in your private cloud. If you set up LinkStation at home, then this is your private cloud. You can access your media files via all private DLNA devices (TV, game consoles, laptops, tablets, network audio players).
  • WebAccess - free apps and access from anywhere with just one click
    With Buffalo's free WebAccess service, users can set up a private cloud on the go that allows them to conveniently access or share their data over the Internet from anywhere. All you need is a smartphone or tablet and the free app from Buffalo for iOS, Windows or Android - and you can access all of your digital assets stored on LinkStation Buffalo's LinkStation can also stream up to four HD movies simultaneously, so that all family members can watch their favorite movie at the same time on their own device.
  • Equipped with reliable NAS HDDs
    This series is completely equipped with special NAS hard drives - for even more performance and reliability in RAID and continuous operation.
  • Restricted network access
    Set access restrictions at group and user level to protect your data.
  • Gigabit Ethernet connection
    The integrated Ethernet connection with 10/100/1000 Mbit/s provides high-speed network connections.
  • Back up all data
    Users can back up data content on up to five computers for personal or business use. Windows PCs use the award-winning NovaBACKUP Buffalo Edition, while Mac computers use Time Machine: Now nothing more stands in the way of data backup from several clients!
  • Quick and easy installation
    The Buffalo devices are easy to install and configure using a simple web-based interface.
  • Direct transmission of multimedia files
    The direct copy function automatically transfers media files from your digital camera or camcorder to your LinkStation website.
BUFFALO LinkStation 220DR - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
Max Supported Capacity
8 TB
8.7 cm x 20.5 cm x 12.6 cm
1.7 kg
1 x Marvell ARMADA 370 800 MHz
Storage Controller
RAID 0, 1, JBOD
Hard Drive
2 x 1 TB SATA 6Gb/s - Western Digital
10Mb LAN, 100Mb LAN, GigE
RAM
256 MB
Android 4.4 (KitKat) or later, Microsoft Windows 7 / 8.1 / 10, Apple iOS 10 or later, Apple MacOS X 10.11 - 10.14
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
8 TB
8.7 cm
20.5 cm
12.6 cm
1.7 kg
Enclosure Colour
Processor / Memory
Processors Installed
RAM
256 MB DDR3
Storage Controller
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - 3.5"
2 x 1 TB
Interface Type
SATA 6Gb/s
Manufacturer
Western Digital
Network / Transport Protocol
TCP/IP, FTP, HTTP, HTTPs
Remote Management Protocol
HTTP, HTTPS, NTP
Network Services Compatibility
Microsoft CIFS, FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Auto-uplink (auto MDI/MDI-X), BitTorrent Client, Apple Time Machine compatible, Direct Stream Digital (DSD), DLNA support, Twonky Beam support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
Expansion Bays
2 (total) / 0 (free) x internal
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
External power adapter
19 Watt
Power Consumption Stand by
13 Watt
Software Included
NovaBACKUP Buffalo Edition (5 licences)
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Capacity: 2TB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Brand: Buffalo
Price Range Ex VAT: 150 - 300
