Buffalo HDD Ext 4TB Drivestation USB3 Black
Quicklinx: CZK1WS00 Mfr#: HD-LC4.0U3B-EU
Select:
  • 4TB
Buffalo's DriveStation (HD-LCU3) is an easy-to-use, economical, and silent solution, that enables users to quickly store, access, and transfer files, digital images, documents, and back-ups. Just plug it in to almost any device with a USB port and Buffalo's DriveStation will instantly expand your storage. The HD-LCU3 features a sleek chassis, that can be positioned vertically or horizontally and has specially-designed interior bumpers to help ensure near-silent operation. Together with eco-friendly auto power on/off, Buffalo's DriveStation is a smart choice for any user.
  • Eco-friendly
    Auto power on, and off, works in sync with attached devices.
  • SuperSpeed USB 3.0
    Buffalo's HD-LCU3 features SuperSpeed USB 3.0. Simply plug it into any available USB port and instantly add capacity.
BUFFALO DriveStation HD-LCU3 Series - hard drive - 4 TB - USB 3.0
Hard drive - external (desktop)
4 TB
3.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Silent HDD, ECO, Apple Time Machine compatible, software encryption, power management support
Power Source
Included AC adapter
3.9 cm x 18.7 cm x 12 cm
1 kg
4 TB
3.5"
USB 3.0
Internal Drive Interface
SATA 3 Gb/s
3.9 cm
18.7 cm
12 cm
1 kg
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Compatible Bay
3.5"
Power Source
Included AC adapter
Power adapter
Power Consumption
18 Watt (maximum)
Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.7 or later, Windows 8, Apple MacOS X 10.5 - 10.8, Windows 8.1, Windows 10
1 x USB 3.0 cable - external
5 °C
35 °C
20 - 80% (non-condensing)
