Buffalo DriveStation Velocity 4TB
Quicklinx: CN9CWS00 Mfr#: HD-LX4.0TU3-EU
Form Factor: 3.5"
Capacity: 4TB
Interface: USB 3.0
£86.24 ex VAT
£103.48 inc VAT
DriveStation Velocity is the perfect solution for those who need to transfer files quickly and easily. The amazing speed performance comes from a combination of a more efficient improved USB 3.0 interface, Buffalo's enhanced TurboPC EX data transfer and copy utility and a 7,200 rpm drive. If you haven't moved up to USB 3.0 yet - DriveStation Velocity is backward compatible with USB 2.0.
The unit is also optimal for users who want to restrict access to their personal drive when on a shared computer or network. Powerful yet easy-to-use security options include automatic hardware encryption that protects your data, with no loss of performance.
  • SuperSpeed USB 3.0
    The USB 3.0 interface is ideal for video and other data intensive digital content.
  • TurboPC EX utility
    TurboPC EX adds more performance to Buffalo's TurboPC with TurboCopy performance and copy enhancement utility. Saving, copying, and transferring files is even faster.
  • High speed 7,200 rpm hard disk
    The disk reads and writes data faster, so you spend less time waiting when transferring and saving files.
  • Hardware disk encryption
    256-bit AES Full Disk Encryption (FDE) protects your data from unauthorized access on PCs.
  • Back up your files
    Buffalo's backup utility automatically backs up your Windows PC, protecting your data.
  • RAMDISK virtual disk utility
    The Windows RAMDISK utility creates a small "virtual hard disk" using your computer's RAM (random access memory).
  • SuperEco
    It saves power consumption during stand-by mode by auto power off.
  • Plug and Play connectivity
    Connecting and using the drive is simple-just plug it in to any USB port on a computer or other device you're connecting to. No need to install any drivers and no confusing settings.
  • Fully backwards compatible with USB 2.0
    No adjustments are needed, just plug into any USB 2.0 port.
BUFFALO DriveStation Velocity - hard drive - 4 TB - USB 3.0
Hard drive - external (desktop) - Hardware Full Disk Encryption (FDE), automatic backup, ECO, cooling fan, power management support
4 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
7200 rpm
Hardware Full Disk Encryption (FDE), automatic backup, ECO, cooling fan, power management support, 256-bit AES
3.9 cm x 18.9 cm x 12.3 cm
950 g
Europe
4 TB
Hardware Encryption
USB 3.0
3.9 cm
18.9 cm
12.3 cm
950 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type B
Power supply
Power Consumption
18 Watt (active)
Software Included
Buffalo Tools
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 or later, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Plug and Play
Europe
5 °C
35 °C
20 - 80% (non-condensing)
Form Factor: 3.5"
Capacity: 4TB
Interface: USB 3.0
Brand: Buffalo
Price Range Ex VAT: 50 - 100
