The Buffalo DriveStation Quad is a high performance, multimedia, USB 3.0 external hard drive perfect for the home or small office that requires large amounts of storage space. The unit is a four drive; four bay RAID enabled drive with RAID 0 for performance and RAID 5 or 10 for redundant storage. The DriveStation Quad gives additional storage to quickly backup all your multimedia files.
With data transfer speeds of up to 300MB/s, compatible with Windows Server 2003/2008 and available with NovaStor NovaBACKUP Business Essential backup software, the DriveStation Quad quickly backs up your entire server system and database.
The DriveStation Quad comes complete with the Buffalo Tools suite of complimentary software that offers enhancements such as TurboPC and TurboCopy to improve the file transfer and copy performance of the drives. The DriveStation Quad features the capacity, redundancy and performance required for any demanding user, the perfect solution for backing up large servers or multimedia files.
- BUFFALO DriveStation Quad USB 3.0 - hard drive array
- Hard drive array
- Total Array Capacity
- 24 TB
- Interface
- USB 3.0
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- Supported Drives
- SATA-300
- Storage Controller
- RAID (SATA 3Gb/s) - RAID RAID 0, 1, 5, 10, JBOD
- Hard Drive
- 4 x 6 TB HDD SATA 3Gb/s
- OS Required
- Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.4 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- Power
- AC 120/230 V - 50/60 Hz
- 14.9 cm x 23.3 cm x 15.4 cm
- 5.5 kg
- 2-year warranty
- Hard drive array
Chassis
- 4
- Supported Devices / Modules Qty
- 4
- Supported Drives
- SATA-300
Storage
- 24 TB
- HDD Array External Interface
- USB 3.0
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, JBOD
Hard Drive
- HDD
- Capacity
- 4 x 6 TB
- Interface Type
- SATA 3Gb/s
- Expansion Bays
- 4 (total) / 0 (free) x internal
- 1 x USB 3.0
- OS Required
- Software Included
- Buffalo Tools, SecureLockMobile, NovaBACKUP Business Essentials (10 licences)
- Plug and Play
- Power Device
- External power adapter
- Voltage Required
- 90 Watt
- 14.9 cm
- 23.3 cm
- 15.4 cm
- 5.5 kg
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
